Hello experts,
A file name of nsm failed to delete objects. I got a folder on my computer desktop with an operating system of Windows XP, the folder name was nsm and I want to delete it since it has no content. But when I tried there is an error occurred saying unable to delete objects. What can I do to delete the item and what is the reason why I can’t delete it?
A file name of nsm failed to delete object.
Hi Deborah Hall,
Thanks for sharing your problem with us, you can use cmd to delete this file. Just follow the following steps:
1. Click on the start button and type cmd in the search box.
2. Choose cmd from the program list.
3. Type CD to change the directory to C: /drive. Then Press enter.
4. Type CD and then type the address of the directory that contain the file. Then Press enter.
5. Type del and then type the file name which you want to delete. Press enter.
I hope this will solve your problem.
Removing/deleting files from your folders should be done with caution especially if you are not aware as to the nature of a file that you see from your PC, for deleting it might be harmful to your operating system (e.g. .nsm.exe). A .exe file must first be located which program does it belong. Only then you may safely uninstall the program.
You may also run your anti-virus program to delete the file. Remember that if you are already certain that the removing nsm file is not harmful to your OS, only then that you try to delete it manually.
