EdhartBrll
Posted on - 09/15/2011
I’m trying to send my files specifically jpg pictures into compress zip folder but this message “ File not found or no read permission” appears which blocked the zip processing, this files consist of 174 jpg pictures which I need to divide for about less than 25mb for much organize and clean email processing. I need to do this way for this is the instruction given by my client.
This message appears blocking the zip processing.
So please help. I’m using windows 7, for I'm having a hard time zipping files just for these error.
My files are located on the desktop much easy to find.
File not found or no read permission?
When compressing file by use of winzip or any type of zip file, some has this limitation to zip the file. I'm not sure if Microsoft has this limitation but the error you're getting is pretty interesting. Interesting because I haven't tried this yet. I'll do some research if Microsoft has this feature.
So far, it has no concrete solution yet to this issue when doing zip file on a larger scale basis. Windows 7 has this barrier that can't be cross when zipping file. But it should work if using 7-zip when zipping small file but not in larger one. Larger that might reach into GB or a quarter. L
