File recovery for windows operating system.
I am a user of windows XP professional.
I was attacked by a virus which had deleted my important files and it also disable my system restore option.
I will in big problem if I do not recover my files.
Do anyone have any idea how I can recover my file or is there any software which can help me to recover my files?
Best Answer by oliverpowell
Answered By 0 points N/A #128008
You can try to use the "Recover My Files" software.
This is free to try but you will need to purchase it afterwards to be able to continue using it.
Just download it and install on your computer.
Click link here;
Answered By 50 points N/A #128009
Virus usually marks your file as hidden and far away from reach of your operating system.
Using data recovery software and recover it but you need to be a little professional.
Follow the steps below:
  1. Download professional or free data recovery software whichever best suites you. You can do so by simply googling the term 'Professional Windows Data Recovery Software' and try anyone.
  2. Install the program and run it from programs section
  3. This will guide you through each and every steps to get back your data.
    Note: You need to have another hard drive of same or more size than the problem hard drive.
Hope it helps!!
Oliver
