File sending software with no uploading necessary
When sending a file to someone over the internet mostly one needs to upload it and send. What I would like to ask if it is possible to send a file of any quantity, size or type wherein one does not need to upload it? Is there a file sending software of such? And if there is can anyone care to tell me how is it possible?
Best Answer by Dyer Pearlman
Answered By 5 points N/A #145181
Hello Sjohn,
There is no available software that transfers files without uploading. To send small files you can use Skype,Yahoo, Msn etc. but to send large & too many files you have to use file sending software. There are many software of this type in Internet. You can also download them for free. But you need to upload your files into this software.
Regards.
Answered By 0 points N/A #145182
Hi Sjohn,
To send a file over the internet requires uploading it first. When you upload it, it is stored on a temporary location and then the sending application gets it from there. Now for you to send files irrespective of their size, I would recommend the following software.
LargeFilesASAP (http://www.largefilesasap.com/)
This sends files of any size. You send to one recipient at a time. You are required to upload the file you want to send then the receiver will get the download link.
File Convoy (https://www.fileconvoy.com)
This is another tool for sending large files without registration.
