File Size For Office Xp 2003 Free Download And Its OS.
Hello what will be the file size for the office xp 2003 free download also notify the supported OS for the same as well. Thanks for solving.
Hi, the file size for the office xp 2003 free download is nearly 450 Mb and can be shared or downloaded overt the search engine and gets easily installed as well. Below shows the various Supported OS for the same as well:
• Windows 95
• Windows 2000 professional
• Windows 98
• Windows 2000 Server
• Windows 2000
If you want to know how big will it be like when you install Microsoft Office 2003 then here it is. Microsoft Office 2003 supports Windows 2000 Service Pack 3, Windows XP, and Windows Vista including Windows Server 2003. It requires 300 MHz or faster processor, 128 MB RAM, 400 MB hard drive space, optical drive, and 1024 x 768 screen resolution.
The 400 MB hard drive space requirement is the total amount used when you install the entire Microsoft Office 2003 suite but the final amount will still depend on the features you will install. The entire suite includes the following applications:
Microsoft Office 2003 can only be used on NT-based versions of Microsoft Windows and is not compatible with Windows 98, Windows Millennium, and Windows NT 4.0. This is the last version of Microsoft Office that is compatible with Microsoft Windows 2000.
