FileMaker database software is displaying the error below on Windows 7. I created that specified file on FileMaker and am wondering where the error is coming from. Please help.
FileMaker Pro
“Sample.fmp12” was not created by FileMaker or is severely damaged and cannot be opened.
You should try recovering the file with the newest version of FileMaker. The update can be found on the FileMaker website www.filemaker.com under Support.
Another option is to use a program to reset the type, author and extensions of the file. A shareware program for this is called XRay and is usually helpful in this kind of situations. It is avaliable on the site https://brockerhoff.net/xray/index.html.
