FileMaker Pro has been installed incorrectly
I have been trying to install FileMaker Pro 12 for the past 5 days now but have been failed to do so on my Mac OS X 10.7.
I have stuck with the error listed below.
I really have no idea what this issue is all about and how to get past the same
FileMaker Pro
FileMaker Pro
This application has been installed incorrectly or modified by another program.
Please run the Installer to get a fresh copy of the application after determining the cause.
Best Answer by Carl Jack
Answered By 0 points N/A #147995
The installer runs through the installation without prompting you to enter the 35 digit license key.When the FileMaker pro 12 is launched after installation, the message you encounter appears.
What to do:
  • Use the assisted Install.txt file (in the Al_License Key section, enter the 35 digit serial number included with your software).
  • Then run the installer.
Thank you.
Answered By 10 points N/A #147996
Hello Dudley,
To resolve that issue, you will need to reinstall the previous version of FileMaker Pro and then update it to FileMaker Pro 9.0v2 using the following steps:
  • First of all quit FileMaker Pro 9 and/or FileMaker Pro 9 Advanced if they're running.
  • And then find your FileMaker Pro 9 or FileMaker Pro 9 Advanced folder. They are usually in the Application folder.
  • After that you will need to open the above folder and after that move the FileMaker Pro 9 or FileMaker Pro 9 Advanced application to the trash. Be careful not to empty the trash until the update is successful.
  • After that transfer the FileMaker Pro application file from the "FileMaker.old" folder to your original FileMaker Pro 9 or FileMaker Pro 9 Advanced folder, and then execute the updater program again.
  • Once it has completed launch FileMaker Pro 9/Advanced.
Nicke
Answered By 60 points N/A #147997
Hi Dudley Achan,
It has many ways in Finding the best site for downloading Filemaker Pro. Some downloaded installer may be corrupter and damaged. You must check the most reliable sources about it. Read some post from other sites. I can suggest you some good forums, which are listed below:
Hope it help you with your concern.
Thanks and more powers.
Answered By 0 points N/A #147998
Excellent solutions guys and thanks for the information. Carl Jack, your solution stuck in my mind. I did as you suggested: I reinstalled the previous version of FileMaker Pro, then updated it to FileMaker Pro 9.0v2 following you easy step-by-step instructions. Now I am happy to see that I don’t get this type of error message anymore. Thanks again Carl Jack for helping me.
