Both database software is reasonably priced but I'm not concerned about the price, because functionality, ease of use, and efficiency is what I am looking for.
Which is better in terms of the things I require in a database software?
Does FileMaker have multi-platform support because I want to be able to use it in IOS and other platforms.
FileMaker Pro or MS Access
You haven't mentioned clarification on your question that, what type of database function you have to do. Basically, the two you want to use, both are ok with it's criteria. I'm going to point out their significant features so that you can take the decision about them.
File Maker pro v12
It has eye catching layout themes that have the ability to apply one of the 40 stunning new themes. That change instantly your database look.
It capable with other many layout tools for your instance.
By having it, you can drag and drop your file anywhere you want.
You can easily create and modified charts and so faster c than you think.
You can use it iOS platforms soon.
More you can read here- http://www.filemaker.com/products/filemaker-pro/version-comparison.html
MS Access
No chance to discuss more but you can now able to take the decision I strongly think that.
