I normally store data in a remote server. All the machines in our office do. But today when I go to my server and check, none of the documents were there. But when I check from my machine, I see the files. Why does this happen? need a quick solution.
Files ghosting inside the remote file server
There can be few situations when it happens. When you were uploading or connecting with your remote server at that time your connection may be facing problem. So at the end your pc show its uploaded but actually it was not fully uploaded. Another thing is that, your connection route is not working properly. So to solve this problem first disconnect your device from the remote server and connect it again. If your problem is exist after this then restart your pc and try again. I hope it’s solved. If its not solved yet then check your connection settings. After checking your setting if your problem is exist then contact with your service provider, they will check hardware section.
