I have accidentally deleted a folder with some JPEG files so I purchased and installed JPEG Recovery Pro version 5.0. I have recovered the JPEG files but it looks like it got corrupted. The recovered files are split in 2 parts. Why is this so? I'm on Windows XP 64 bit. Thanks.
Files recovered by Jpeg Recovery Pro got corrupted
The JPEG format is a lossy format that compresses the image. So while you are recovering your photos it might lose its details.
You can also try some other softwares. Different softwares work differently.
Some well known Photo recovery softwares are Stellar Phoenix Photo Recovery, Diskdoctor photo recovery, Remo Photo Recovery.
Hope it will help you
Thanks
