My client have a website that is a school site. Next session the client want to admit their student in online. They want a fillable PDF and Word document. But I can’t do this now. But, It is very urgent for me. Who can help me in this respect? What is the accurate process?
Fillable Word Document and PDF
So your need is that you want your clients to fill up online application forms right ?
Here is the ultimate solution for your query. please purchase the new version Adobe Acrobat X Pro software or you can download it from here, install it on your system and start working as it instruct you to do.
This may be a little bit expensive to you, but this suits you the best for your job.
Have a nice day.
bemmy
Yep , understood your problem, if i am correct you need to edit the PDF document right?
Then , go here for the solution , you can use Nitro PDF reader where you can edit the PDF document and you can fill the data where ever you want.As you know that PDF files are not modified or edited easily . Here there are few solutions where you can make few minor changes to a PDF file.
For instance if you want to hide any number or word before publishing it on the web and to stick it to the pages you can go for PDFescape
If you like to edit the meta data if any held up with the PDF document you can go for BecyPDFMetaEdit program, its free utility tool that helps in editing the title, author name. keywords etc. Tool is also used to encrypt the data by using the passwords.
Third one which might mostly suitable to you where you can edit large amount of text in a PDF file by converting them to editable Word or Spreadsheet documents and then to PDF documents for this you can use the BCL Research or Nitro PDF.
Editing the Images in the PDF file. PDF Xchange is PDF image editor where you can edit PDF document directly. And finally the Inkscape is the a free image editor tool just like Adobe Illustrator that basically imports and exports editable PDF files.
