Hi.
I was just trying to add a filter but I can’t and this attached error message keeps showing up.
I don’t know what this is about; please tell me what I am missing.
Microsoft InfoPath
A filter cannot be applied to the currently selected field. Select a different field.
OK
A Filter cannot be applied to the currently selected field
Hi John,
Your Problem is not far different from other InfoPath user. That is a common error that has been encountered by a lot of individuals. You can check some forums that tackles about the cause of it (you can also directly click the link that I have attached to lead to directly to the forum).
InfoPath Forum
Hope it helps you a bit regarding with your concern.
Thanks and more powers.
