Final Cut Express Quits on Launching
I am trying to launch Final Cut Express on my Mac OS X. But the error below is showing. It just keeps on quitting when opening. I tried to uninstall the program and then re-install it back only to get the same error message. How can I resolve this issue?
The application Final Cut Express quit unexpectedly.
Mac OS X and other applications are not affected.
Click Relaunch to launch the application again. Click Report to see more details or send a report to Apple.
Ignore     Report…     Relaunch
Answered By points N/A #120566
In order to fix this issue, you might need to delete Final Cut Express preferences. To do so,
1. Go to “~/Library/Preferences”.
2. Delete the file called “com.apple.finalcutexpress.plist” from the Preferences folder.
3. Also, delete “Final Cut Express User Data” folder from there.
Also, create a new user account and then open the project under the user account. Don’t forget to make the account with administration privilege.
Also, try removing Final Cut Express and then re-install it.
