I have only problem when I try to import video files in Final Cut Pro 7.
What could be the cause of this annoying error message.
I need an expert advice so that I may fix this error.
Any help would be really appreciated.
Thanks in advance.
Warning “BDMV” contains unsupported media or has an invalid directory structure.
Please choose a folder whose directory structure matches supported media.
Final Cut Pro 7 error. BDMV contains unsupported media
I hope you are using a camcorder for which you need to follow these steps:
Make new folder on desktop.
Drag the private folder in it.
Point the add volumes location to that main folder.
Now see if it helps.
If you are loading files from various sources, first save into HDD. Then later you shift those files into the project folder, to edit in Final Cut.
If you are trying to edit a video with Final Cut Pro, check that the format of the video is supported. The error in the dialog points to either the media file you are trying to load or the directory or folder where the file is located. The following video file extensions or container formats are supported:
- 3GP (*.3gp)
- AVI (*.avi)
- MOV (*.mov) (QuickTime file)
- MP4 (*.mp4)
- MTS/M2TS
- MXF
If you are inserting a still image file, the following formats are supported:
- BMP (*.bmp)
- GIF (*.gif)
- HEIF (this requires OS X 10.13 High Sierra)
- JPEG (*.jpg or *.jpeg)
- PNG (*.png)
- PSD (*.psd both static and layered)
- RAW
- TGA
- TIFF
If you are adding music to the video, the following audio formats are supported:
- AAC
- AIFF
- BWF
- CAF
- MP3 (*.mp3)
- MP4 (*.mp4)
- RF64 (requires OS X 10.13 High Sierra)
- WAV (*.wav)
