Find 82801db Intel LAN driver download for my mother board
I am using Intel 82801 DB motherboard. Now, I want to download LAN driver for windows XP for my motherboard.
Where can I find 82801db Intel LAN driver download for my motherboard?
Hi Jamior,
You might want to visit the Intel website to download the drivers for your motherboard.
If that doesn't appear to be the proper drivers for your motherboard, you can search Intel's driver database to find the driver that is right for your needs.
I hope that helps.
Katelynn
Thanks for writing to Techyv regarding your concern:
For your Intel 82801 DV main board you find the LAND driver provided with your motherboard disk when you have bought it. Or you can download the LAN/Ethernet Driver from their download center. Chick on the link and it will take you to Intel's website where you can download your driver.
Don't forget to reboot your computer after installing the driver.
Hi Jamior Miston
Check out below Techyv link too because here you will get more information about your question.
Notifications
