Find all URl’s in my website and which are not indexed?
Find all URl's in my website and which are not indexed?
is there any site/tool/software that can check all URL's in my website and tell me which are not indexed in Google.
Thanks
Thanks
You should use Xenu’s Link Sleut. It checks every single link on webpage, report broken links on web sites and verifies regular links. Detecting of redirected URLs is reported. It supports SSL websites, partial testing of ftp, gopher and mail URLs. It generates html report and you can even customize analysis. The only disadvantage of this software is long time needed for the checking. But, it is easy to use with simple user interface, as you can see in picture:
You can download free program here:
https://xenus-link-sleuth.en.softonic.com/
Everything written above shows that Xenu’s Link Sleut is extremely valuable tool.
