Find Device On Network By Mac Address
Being in IT industry, you might face a situation where you do have a MAC address but want to know about the IP address. How to find device on network by Mac address?
HOW TO GET IP ADDRESS FROM A MAC ADDRESS:
1) DHCP SERVER
• Every desktop has an IP address assigned by DHCP server.
• From the Windows Server, go to the DHCP console.
• Select address leases. You can view the IP as well as MAC address.
• If you have a wireless router then on the AT&T U-Verse box click device details.
You can see the MAC addresses.
2) PING BROADCAST ADDRESS
Method 2 – Ping Broadcast Address • Open start menu.
• Search command prompt.
• Type: ‘ping along with your subnet’.
• You will get request timed out four times.
• Type arp-a.
• List of all the connected devices with the IP address will appear.
