Find error in a Java Program
The code given below is a Java code.
Find out that after the execution of the code the exception "array index out of bound" has occurred or not?
Also identify the mistakes in the program if any? And then write the correct program. ————————————————————— public class Excep { public static void main(String [] arr) { try { try { int array[]=new int[20]; array[100]=5; } finally { System.out.println("In Finally BLock.."); } System.out.println("Outside Finally Block.."); } catch(ArrayIndexOutOfBoundsException EX) { System.out.println("In Catch Block…"); } System.out.println("Exiting…"); } }
