Find me the latest version of melhor rom optimus 3d
I forgot to update my optimum 3d, my versions is melhor rom, and now I simply need a feature in the newest version. Find me the latest version of melhor rom optimum 3d.
If you can launch the application right from your desktop, try opening it then check if there is an Update link available on the Help menu. This is usually where the update option is located. But if it is not available there, try clicking on the Help menu then select About. Check the About window for the software’s home page.
Open your web browser then go to the site indicated in the About page of the program. Just search the site for an update for your program’s version then just download it. Install it afterwards to upgrade your present version.
