Can this connect to multiple devices at a same time? How is it storage capacity? Is there any AC plug adapter? How is its battery life? Can this streaming media to DLNA devices, TVs, consoles? Can other people connect this wirelessly for file sharing? Can I recharge the battery by plugging in the USB cable? Is there any button for WI-Fi Protected Setup and how does it work? How can I configure SSH and FTP access to admin tab? Thank You
Find more characteristics on WD My Passport Wireless
Hello Bobbye!
This devices gives you avenue to connect with multiple devices, save your files, access and share it at the same time. The storage capacity of this device differs in the available disc drive.
It will always show you the available free space. You ca connect it with Xbox 360, Play Station 3, WD TV Live media player, and other mobile devices. It uses USB cable and pugging it in the adapter to recharge it from a direct source. There is a WiFI password protection for keeping other people from accessing your device. SSH and FTP determines the type of access of the user. With this any person will try to connect with this device will still need to specify password. Thus making it more secured from getting accessed by non-affiliated devices. You just need to view or modify the type of Access by toggling the switches from left to right by moving the throttles.
