jowel007
10 points
Posted on - 11/25/2011
Upon buying a new computer, the store or the seller can't provide the list of all the hardware parts that he or she installed.
Or when time passed by and the user can no longer remember the specs of their own pc's.
I want to know now how I can find the specs of my own computer?
Where and what should I click to locate all the parts that has been installed on my pc?
Thanks and regards!
kean b
How to know my computer specifications
Hi Jowel,
To find out the name of the device driver's installed on your system. Follow the steps below.
For Windows XP
1. Go to Start and select Control Panel
2. After that Double click the System icon
3. Open the Hardware tabÂ
4. Select the Device Manager button
5. The Device Manager will show the list of hardware devices that installed on your system.
6. To open the device, double-click on it to show its properties
7. Select the Driver tab. It showed properties and how old already is your driver installed on your computer system
For Windows Vista
1. Go to Start menu and select Control Panel
3. Select Advanced System Settings under Task option.
4. If the User Account Control pops up and ask for permission, click Continue.Â
5. After that, select Hardware tab and click Device Manager. This will now show the list of hardware devices installed on your computer system.
6. Double-click the device to show its properties and select Driver tab. It will show now properties and when the driver installed on your computer system.
For Windows 7
1. Click on Start Menu
2. Find Computer and right-click on it.
3. Select Manage and click Device Manager under Computer Management and System Tools. This will show the list of hardware devices installed on your computer system.
4. Double-click the device to show its properties and select Driver tab. It will show the properties of the driver installed on your computer system.
Regards
Kean B
p3mburu
Hi there.
If your operating system is Windows, and If you don't have the driver CD, you still can find the correct drivers for almost any hardware devices. There's a software that will helps you to do this. The software is Driver Max. You can download it here: http://www.innovative-sol.com/drivermax/. Max driver is not only the best hardware without Windows drivers backup utility, but can do more than backup and restore Windows drivers.
The software lets you quickly check for updates to device drivers and identify unknown hardware in your computer. But to access this two features, require that you register an account first. Once you installed the software, on the main window of the driver max, click the "Identify Unknown Hardware" button. Then Driver Max will start to look for drivers for hardware devices known in its database and will displays a list of matching drivers.
Now you can download the drivers that you need.
