Find Out Why Your PC Is Running Slowly
To find the processor speed and amount of random access memory (RAM) in the Windows 7 operating system:
Hi
Slow PC is a real headache when doings some important works. There are lots of reasons that can make your PC slow. Some of them are random, and some of them are systematic problems.
For example, if you install the latest version of Kaspersky antivirus software for a Pentium 3 machine. It will slow down the machine massively.
Another thing is the operating system. Always try to use appropriate operating system for the refinements. Do not go for the latest one. This theory is not only for the operating system but also for the all the software that you use.
Always keep enough free spaces in the hard disks. Especially in the partition that OS was installed.
You did not mention your computer specifications so we can identify why it is acting so slow.
Your computer will slow down when applications or programs are installed and used.
And we have to know if you have enough space on your computer memory to be able to run those programs without hassles. You also need to stop unused applications. Check your system tray to check those applications running on the background on your task manager and then End all the process that you think unusable. Clean your Recycle Bin often.
Uninstall all the applications that you no longer need. Run defragmentation and always keep your computer up to date.
And lastly, run your antivirus and scan your computer.
