kamnagarg
Posted on - 08/07/2011
We have a text file which contains names of other files having various extensions e.g. .mp,.html..doc etc. how to find the rows/file names present in the text file which has extension .doc and .html and put it into another text file?
Dplus
Find a particular extension in a text file
Fail to find your document,first you have to search for library and documents if you have Windows 7 or Vista. For html you can use Adobe CS3 Dreamweaver apps. There you can easily find. And a text file you can go your office package if you use it, or go the recent documents if don't delete recent documents. In every folder you can use shortcut way to use F3 and write the file name to find. If windows 7 it also stays on your right bar on top of the monitor. Or go to 'C' drive user and search your documents. If you have Windows Xp then you can find pressing start menu and search option and paste the file name or doc.
