Finding app that can send message to multiple recipients
I am currently facing a problem for my work. I am looking for an app that will allow me to send multiple text to a group of people simultaneously. Also, on top of that, I want people to respond to this group text individually so that the other respondents are unaware of the response of others. Can anyone help me?
Answered By 0 points N/A #189613
You can do that without using any apps by following these rules. First, you typed your message, then click on your contact button and select multiple contacts and send.It can be easily done. But if you feel disturbed doing that you can do that by many apps. Google Play has an app called Send Multiple SMS Messages that can help you for sending group messages but it is available only in Android. Other apps called GroupMe. It is available on iPhone, Android, Blackberry. By using this app you can send group messages easily.
Answered By 590495 points N/A #189614
You don’t actually need an application to send group text messages to a number of people. Your mobile phone or your Smartphone is already capable of sending group text messages to a number of individuals in your contacts simultaneously. A group message is just a single text message sent to multiple individuals or recipients.
The message or group message you sent to them will appear as if you texted them individually. This way, they can reply to your text individually. To send a group message, go to write message and compose your text message. Once you are finished, add recipients by selecting multiple contacts from your phonebook.
Once all contacts are selected and added to the recipients, send the message or the group message. Normally when you send a group message, it will show you a progress bar displaying the number of messages already sent.
