Finding duplicate photos cluttering my PC
Can anyone help me giving instructions about how to find duplicate photos quickly those are cluttering my PC and manage them using ‘VisiPics’?
Thus the instruction to find duplicate image on your computer,
Follow this instruction:
1. Install VisiPics on your computer.
2. Launch VisiPics program, click File then Add Folder.
3. A Pick Directory window will pop up, choose a directory you want to search for a duplicate image then click OK.
4. The directory location will show up in a program, you can add more directory by clicking on a directory tree and click (+) button, the folder will show up below the first folder you add.
You can also delete the folder from the list by clicking (-) button.
5. Click on Play button (A button with green triangle).
6. The duplicate images will show up in the left side column.
7. Mark the duplicate images you want to delete, move or rename then click ok.
