Finding Notepad for Nokia C3
Yes, it is possible. In this day and age of app development, it is possible to find an app for many phones on the market. The Nokia C3 is no different. I have attached links for you for software downloads that is either a notepad or a software that serves the same purpose as a notepad or WordPad.
http://www.mobiles24.co/downloads/s/439084-m1234-notepad_40
Hi Bretty Grey
It is possible to have a notepad which can also save text files in Nokia CS3.
There are multiple apps of text editor for Nokia CS3 some are mentioned below.
1.  Mini Notepad 2.01
2.  VVS EBook reader S60
Both are really good but I’ll strongly recommend you a Mini Notepad 2.01.
1.  It is a small light weight notepad for taking notes.
2.  It also allows you to create, delete, update and save notes on your Nokia CS3.
3.  It has a friendly user interface.
4.  Easy to understand Mini Notepad 2.01
I hope you’ll like this app. Enjoy and have a fun!
Johnstoon Leen
