Finger Printing Scanner after Windows Upgradation
I am using Fingerprint Scanner which is not working after Windows 7 upgraded. i have installed the driver for the same but that also does not work for me. Whenever i am log in the Windows 7 it shows that can't find a fingerprint reader. I am using Toshiba Satellite U205-S5034, if any one having the solution for the same then help me with the same. Thank you.
Answered By 80 points N/A #93439
There are instances that after an update or an upgrade of your Operating System, some of your applications will not work properly. This is because aside from the changes you made on your Operating System you will also need to update the drivers of some programs to make them compatible and work on your new OS. Other drivers may also need to be uninstalled then reinstalled to make them work after the changes, meaning, you will have to try any of those to isolate the issue further and to make the affected application work properly after the changes that were made. You may want to go to https://support.hp.com/bg-en/document/c02519007for further assistance regarding this matter.
