AuthenTec’s fingerprint software Protector Suite shows this following error message at every launch. How can I solve this problem? Can anyone help me? I would be grateful for any kind of assistance. I am using Windows 7 Operating System. Thanks in advance.
Fingerprint software
Arithmetic operation resulted in an overflow.
Details
Error code: Description
FFFFFFFF Arithmetic operation resulted in an overflow.
Close
Fingerprint software error has occurred
This error basically explains itself brilliantly.
The cause of this error is some calculation at the programming level that produces some result that has a value greater than the expected value. The programmer used less memory for the storage of the result but this time the result is a larger value.
In other words this is caused due to a bug in the software.
If this error occurs every time you run this application then the solution will be to reinstall this application or update the software. Such errors are caused because of the programming level issues hence there is usually no way to solve them unless we have the source code. The company will address to this problem and solve it.
So please check for the updates or reinstall this application.
Hope you understood the problem and got your answer! 🙂
