ayannahana
10 points
Posted on - 12/11/2013
Hi there,
I have FireFox 26.0 which Tweaked a bit to increase my browsing speed, I changed Network. Pipping from 32 to 35, then introduced browser. Turbo. Boolean to true, since then my computer (Acer Aspire running on Windows 8) is freezing every time I start Firefox, I want to reset the browser to its defaults but the freezes are not allowing me to navigate the application, how do I solve this one? And why are these changes freezing my computer off every time I start the application?
Firefox 26.0 freezing computer after changing settings
Hi Ayannahana,
There are multiple solutions to solve the Firefox freezing problem.
Solution 1: Changing the settings of Firefox
1) Click on the Firefox button, Select 'Options' button
2) In the Firefox options, Click 'Advanced' button
3) Click 'General', the settings list will open in the system
4) Uncheck the checkbox 'Use hardware acceleration when available' checkbox
5) Restart the Firefox after the settings are applied
Solution 2: Using Firefox in safe mode
1) Click 'Firefox' button, go to the 'Help' menu
2) Select 'Add-ons disabled' option, the Firefox dialog box will open
3) Select the option to open Firefox window to open
4) Click 'Start in Safe Mode' option to start the Firefox in safe mode
5) After the problem is solved, close the Firefox in safe mode and restart the Firefox again to work in normal mode
You encountered that problem because of the modifications you did in the internal configurations of the browser. When the browser starts or each time the browser launches, it will keep applying those settings that’s why it always end up freezing. That problem is caused by the settings you applied. Note: when tweaking the internal configurations of the browser, in this case Mozilla Firefox, modify one setting at a time.
After applying or modifying one setting, restart the browser then see if it works. Don’t modify multiple settings at a time because it can trigger compatibility issues in the browser making it unstable to run. To troubleshoot, first thing to try is to run the browser in Safe Mode. To do this, press and hold the Shift key when launching Firefox.
This starts Mozilla Firefox in Safe Mode. In “Firefox Safe Mode” window, you should have two buttons:
- Start in Safe Mode – this button disables all your browser extensions or add-ons and themes and disables hardware acceleration. When you leave Safe Mode and start Firefox normally again, all extensions, themes, and settings will return back to the state before you entered Safe Mode.
- Refresh Firefox – this button resets Firefox back to factory default but saving your important information.
If the problem continues, uninstall Firefox and install the latest. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Mozilla Firefox among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, exit Revo then download the latest Mozilla Firefox and install it. The download button basically downloads the web installer. If you want the offline installer, click the “Advanced install options & other platforms” link.
