Firefox 3.x doesn’t work properly with the Linksys BEFSX41 Router
I use Firefox much and got a lot of work bookmarks and many other things on it. In previous days, I got this message many times that Firefox 3.x doesn't work properly with the Linksys BEFSX41 Router, firmware version 1.5x .
I need anyone to tell me what to do.
Connection Interrupted
The connection to the server was reset while the page was loading.
Best Answer by Alber grower
Answered By 0 points N/A #85973
Good day to you !
It seems that you have the internet on because you have the Google icon on the first tab and another website is opened normally on the next tab. Have you tried viewing the router on the Internet Explorer browser? If it worked on the Internet Explorer browser, then the problem relies on the configuration of your Mozilla Firefox browser.
I hope this procedure helps:
1. In the address bar of Mozilla Firefox enter "About:config" to view the configuration setting of your browser.
2. Then use the filter and type "ipv6" and the result will be "network.dns.disableIPv6", and change the value to false.
This procedure worked for me. I hope it works for you too.
Answered By 0 points N/A #85971
Hello!
I search Yahoo for the answers. I have been in forums asking what causes the problem. I confirmed things with the experts and they provided me with these solutions.
Many people have encountered this kind of problem including me. I encountered this kind of problem a long time ago.
I can see that you have nod32 installed on your system. This is I suspect.
Three years ago, I bought my desktop and installed Firefox. After I installed Firefox, I downloaded nod32 and installed it. After that, Firefox did not work anymore. I think the problem is caused by your nod32 antivirus or the router itself.
These are the compilations of testing solutions and made Firefox work again:
Solution # 1
First we focus on your router.
Check your connection, if it's working or not.
If it is not working, then proceed. Call your internet provider for assistance.
Disconnect your router and connect to the internet without the router. So, put the internet cable directly from your modem to your CPU, then check if your Firefox or FF is working.
Try browsing through Firefox. If your Firefox or FF is still not working, that means your router is fine and perfectly working.
So now, we know that the router is not the problem. If your Firefox works, then we are done.
Second, we go now to nod32 antivirus.
Try to uninstall it and restart Firefox. Then it should work.
Note: If your Firefox still does not work, the problem is your internet. Call your internet provider ASAP
Refer to this address
Solution # 2
Uninstall nod32 and try different antivirus like AVIRA, AVG and other tested and trusted antivirus.
Answered By 0 points N/A #85975
Thank you everyone for submitting the solution. Number 2 works with me. So, thank you.
