y2caye
Posted on - 02/14/2012
Hi All,
Firefox close all tabs right.is there an Add-on for this?
Can anyone help with a Add-on for Firefox that can be installed and when right click on the tabs i get a open to close all tabs right
Thanks
Firefox closes all tabs right.is there an Add-on for this?
I found a Firefox add-on that has a toolbar button that can be used to close all open tabs. It has four other configuration options. If you like to open the homepage after closing all the tabs, whether you like a warning about closing all tabs to appear or not, whether you like to show notifications about the button location and configuration and selection to where to add the button. Here you can find the add-on link. You can find the button added by default to the tabs toolbar, you may add it in any place you need. Hope this may help you. Best of luck
bensoo
There are a couple of add-ons available for Firefox. Have a look at the explained addons below. You can download them according to your needs.
Multiple Tab Handler:This add-on handles multiple tabs at once for ex, close,reload them etc.
Features of this add on are
Close selected tabs
Close not selected tabs
Reload selected tabs
Duplicate selected tabs
Pin/Unpin selected tabs
Move selected tabs to a group
Move selected tabs to a new Window
Bookmark selected tabs
You can customize the tabs with this add on.
Tab Mix Plus:It enhances the Firefox's browsing capabilities with features like reloading,duplicating tabs,controlling tab focus etc.
Close all tabs: A toolbar button to close all tabs in Firefox.
