analyn
10 points
Posted on - 08/11/2011
How could you detect that the firewall is not working at all? I experienced to be blocked and how can you do manually installation of the program? Does it need a code to fix it up? What will be the role of the Firefox to default the access?Â
Justin
Trevor
Firefox code and installation process
You will be notified by your firewall system if it is not working. You will find a yellow or red icon on your firewalls icon on the task tray if it is not working anymore. Firewalls rule is to block you from accessing outside resource or blocking the incoming connection from outside networks. This will block Trojans and Malware to send data outside. It is more important to have this one for you to protect your system.
Your Firefox browser doesn’t have any connection with your Firewall instead, the firewall watches for the activity of your Firefox.
For blocking and unblocking applications access to outside and incoming connections, please refer to your firewalls manual or help file.
