Firefox | Firefox version | Informenter
Latest version of Firefox should be able to run this (I think the latest version is 3.6). Â Remember that informenter is an add-on for Firefox. Â You download and install it to your browser for it to work. Â It is simple to get add-ons for Firefox. Â Just go to add-ons.mozilla.org. Â Search for the add-on you want. In this case, informenter. Â Download it. Â Restart your browser. Â Then enable the add-on.
The benefits of using InFormEnter is that it adds a small, clickable icon next to every input field in a web form, from where you can select the item to be inserted (no typing required). You can configure it to display your frequently used information such as name, email, address. Â This can be very useful when you fill up lots of forms online since it saves you the time and energy of typing everything again and again.
InFormEnter is an add-on for the Mozilla Firefox web browser which supports Mozilla Firefox 1.0 and later versions.
This add-on inserts a small, clickable icon opposite every input field in a web form.
This lets you pick the item to be inserted which doesn’t require any more typing on the keyboard. You can set it up to show the information you most frequently used such as name, address, email, or anything you want to make available from the form menu.
It supports languages like English, Polish, Slovak, French, Italian, Dutch, Russian, and German. It has 27 versions and the latest version is available.
You can view the complete list of the versions starting from the first version, 0.2.4, which was created on May 4, 2005Â
