I am using Firefox browser. If I click any link in emails then, two separate Firefox browsers opens. I don’t know why it is happening. It is really very frustrating. Please, let me know if you have any solution.
Firefox problem : Multiple tabs opening
Hi Debra_McCain,
To solve your firefox about opening another firefox browser, all you have to do is to turn  to the Default theme.  Then select the TOOLS, look for add-ons then click on themes.
You do not have to create any modification on the safe mode of the start window.
If still nothing happens you have to modify all the extensions and attempt  to look for the possible reasons what causing the problem. How?
make use the all add-ons to disable on the start window safe mode to modify all the extensions.
whenever there is changes you have to restart firefox to apply what you have done.
Hope this might help you.
Hello Debra,
I have experienced that before, and it is that big of a deal and therefore it should not bother you.
When you click on Firefox icon or the or the quick launch button, it may seem to take long to open and therefore you click on it several times, then eventually many browser windows will open at ago which correspond to the number of times you clicked the icon. So just close the windows that you are not using to remain with one in which you can use tabbed browsing to surf the internet.
Hope this helps.
__
Regards
Mahesh Babu
