In Firefox see active logins before clearing?
Before clearing my history in Firefox see active logins first? Is that possible? It is not, is there another way to see active logins?
Hi Adams,
I understand that you would like to be able to see and backup your Mozilla Firefox Log-ins with their corresponding passwords. Yes! That's possible! You can actually see them in Firefox's Password Manager and also be able to export them using a Password Exporter. That would be possible if you of course allow Firefox to save your log-in details and password. Below are a couple of sites with guides as to how doing it:
http://kb.mozillazine.org/Password_Manager#Backing_up_and_restoring_passwords
https://addons.mozilla.org/en-US/firefox/addon/password-exporter/
Which version of Mozilla Firefox are you using? On the latest version 15.0.1, you can view all the active logins by following the steps below:
1. Click the Tools on your Firefox browser.
2. Select Security Tab under Options window and then click Saved Passwords.
Note: Only those you agreed to save during log ins will be visible on the Saved Passwords list.
4. Click the Show Passwords button to view the URL together with the username and passwords.
