kurt bakken
Posted on - 09/02/2011
Hi there!
Firefox is the fastest browser for all users. So, I use Firefox for fast browsing.
When I started browsing, some Java script text appears in my browser window. Then suddenly, my browser stopped.
It could not load any flash or general websites.
Please provide me the best answer.
Firefox shows some java script and not browsing
Hello!
Add-ons and other software components are needed to make the computer browser functions properly. Firefox is not an exception.
Firefox's Java Script has stopped  working that is why your Firefox browser stopped. Java needs to be fixed because this helps the browser display specific content, text, images and other software application that needs Java. Java script needs to be installed and or install the updated version.
This helps you view the websites beautifully.
Here's how to do it:
Open Firefox browser
Go to Tools, and choose Options
Click Content icon
Go look for Enable JavaScript and check the box
Go to Advanced button to Open Advanced JavaScript Options page
Put a check on Allow scripts to, click OK
This should let you access your Firefox without error on Javascript.
