Firefox Update Installation And Conflict Error
I want you to check the attached image first and then read the rest of the message.
Ok now if you have checked the error image you might have understood that what my problem is.
Whenever I try to find updates for some add-ons on Firefox I get the updates but just after it shows the updates and I try to install those updates I receive this message that SSL received a record that exceeds allowed limit.
An error occurred during a connection to services. addons. Mozilla. Org:443.
SSL received a record that exceeded the maximum permissible length.
(Error code: ssl_error_rx_record_too_long)
Please tell me that if this error is due to a heavy update file which has a non-permissible size then I will not install that update and if it is not due to that then tell me why is it occurring.
I need to install updates as they are linked to my work.
So I am waiting for your reply regarding its solution.
