Intel CEO has pronounced that the first Intel powered smartphone is going to be available this week and the handset will most likely to be from Lava.What will be its RAM'S size and which operating system will it be based on?
The First Intel-powered Smartphone could have the specifications including an Intel Z2460 Atom chip (1.6 GHz), a 4.03-inch screen (1024×600), 8MP camera, HSPA+, and 16GB flash memory, NFC chip.
It will be based on the operating system of Android 2.3 Gingerbread (upgradable to v 4.0 Ice Cream Sandwich) and will have 1GB RAM.
There are many Intel-powered Smartphones and here’s one, the Asus Zenfone 5 A500CG (2014). The Asus Zenfone 5 A500CG (2014) is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on January 2014 and released on April 2014 measuring 148.2 x 72.8 x 10.3 millimeters and weighing 145 grams.
It is built with plastic frame, plastic back, and glass front. It uses micro-SIM card and available as dual SIM. It has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution protected with Corning Gorilla Glass 3. It ships with Android 4.3 Jelly Bean upgradable to Android 5.0.2 Lollipop powered by Intel Atom Z2580 chipset, 2 GHz Dual-Core processor, and PowerVR SGX544MP2 GPU.
It supports microSDXC card. It runs on 2 GB RAM with internal storage available in 8 GB, 16 GB, and 32 GB capacities. The primary camera supports 8 megapixels featuring f/2.0 and AF with LED flash. It supports 1080p video recording at 30 fps. The secondary camera supports 2 megapixels featuring f/2.4.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with Wi-Fi Direct and hotspot support, Bluetooth 4.0 with A2DP and EDR support, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0 with USB On-The-Go support. It has built-in accelerometer, proximity, and compass sensors. It runs on non-removable Li-Po 2110 mAh battery with standby time up to 353 hours on 3G and talk time up to 18 hours 30 minutes on 3G.
It is available in Charcoal Black, Pearl White, Cherry Red, Champagne Gold, and Twilight Purple colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
