Five Important Types Of Equipments For The Server Room Cable Management
I want help regarding the server room cable management. What type of arrangement must be done in a server room to manage all the cables perfectly?
You can simply buy some equipment to perfectly manage cables in the server room:
• Horizontal Cable Manager – It can be used to manage networking cables and patching cords in the rack so that you can easily identify each and every connection in future for maintenance.
• Vertical Cable Managers – It can help you organize cables to route in a neat manner.
• Cable Tray System – To keep running cables fixed overhead cable tray system is a perfect solution. Tray system has varieties like snake tray, trays suspended to ceilings or under floor cable trays.
• Patch Panels – To enable flexibility and reduce strains in cables.
• Fiber Optic Patch Panels – These adapters let you efficiently fit your optic cables to the enclosures.
