Hello everyone, I am getting a system 80072f8f windows update error. I was informing my system when I got this error, and my apprising crashes in between the process. The window is stuck, and keyboard is not working. Kindly help me with this problem.
Fix 80072f8f Windows Update Error Manually
Basically, sync your system’s time to the internet time server. This process will solve the 80072f8f error.
Follow the steps:
1. Select the start menu and open Control panel.
2. Choose Clock, Language, and Region, and then click Date and Time.
3. Hit Internet Time tab and choose click Change settings.
4. Enter the password you entered if asks.
5. Select Automatically synchronize and press ok.
When checking for new updates via Windows Update, you may receive error code “80072F8F” if the date and time settings on your computer are incorrect or the time zone is incorrect. When you synchronize the clock on your computer with an internet Time Server, your computer’s clock is automatically updated to match the Time Server’s clock. This ensures the clock or time on your computer is accurate.
To fix the problem, first, check your date and time settings. Click “Start”, “Control Panel”, “Date, Time, Language, and Regional Options” then “Date and Time”. In “Date and Time” screen, under “Date and Time” tab, click “Change date and time” then set the correct date and time. After this, click “Change time zone” then set your correct time zone.
When you are finished, go to “Internet Time” tab then click “Change settings”. On the next screen, check “Synchronize with an Internet time server” then select a Time Server from the dropdown list. By default, the Time Server is set to “time.windows.com”. Next, click “Update now” then wait until the synchronization is complete and then click “OK”.
In case an error is displayed saying “The peer’s stratum is less than the host’s stratum”, try setting the Time Server to “time.nist.gov” then click “Update now” again. After this, try Windows Update again and see if it works.
