Hello everyone, I am getting a system 80244019 windows update error. I was informing my system when I got this error, and my apprising crashes in between the process. The window is stuck, and keyboard is not working. Kindly help me with this problem.
Fix 80244019 Windows Update Error Manually
Remove the corrupted files.
Download any software like Reimage Plus and restore or remove the corrupted files.
2. Data execution prevention
Press Win+R, type sysdm.cpl and hit OK.
Navigate to Advanced then click Settings and choose Data Execution Protection. On the “DEP for Essential Windows Programs and Services only” and hit apply then OK.
3. Bound Windows Update
Navigate to Control Panel and variate the View by too large icons.
Search Windows Update and click on Change settings. Dig for “Give me updates for other Microsoft products when I update Windows” and uncheck. Select OK.
When you check for an update and Windows Update cannot connect to the Windows Server, an error “80244019” is thrown. One way of fixing this is to reset the Windows Update Components. Microsoft released Fixit 50202 mainly for resetting the Update Components. To try this, download Microsoft Easy Fix 50202. This will directly download the 50202 MSI file.
Once downloaded, run the program and accept the agreement to continue. Check “Aggressive Mode” then click “Next”. Wait until it is finished and it should restart the computer automatically. After booting, check for updates again then see if it works. If this doesn’t fix it, you can download the update and install it manually. Click “Start”, “Control Panel” then search for without quotes “Windows Update”.
Next, click “View Update History” then get the update number. After this, search Google for that update number then go to the Microsoft website that has the update and download it. Once downloaded, run and install it. Windows Update is a feature built-in to Microsoft Windows that is responsible for protecting the system by checking the Windows Update Server and installing the necessary updates.
It operates continuously in the background checking for updates and applying them. Because it is responsible for protecting a huge number of applications, things can go wrong due to technical and software glitches.
