Fix And Check The Website For 404 Errors
I am surfing the website the so many errors occur, and the error has the number 404, what is 404 error of the website? How to fix and check the website for 404 errors with many methods?
When the page which you want is not found on the server, then the 404 error occurs. The page is removed or moved; URL isn’t typed correctly. It is the client-side error. There are many causes of error 404 like junk registry entry, Browser cache issue, DNS server problems, junk files in the browser.
Steps to fix and check the website for 404 errors:-
Method 1:-
1. Delete all the browser history, cookies, caches, and another plugin data
2. Go to the settings then click on history.
3. Click on the clear browsing history button.
Method 2:-
1. Remove junk files and junk registry files
2. First, download the clean master software.
3. Go to the registry then click on the scan issues.
4. Then click on the Fix selected issues.
5. Now click on, ok.
