Zik Jhonson
20 points
Posted on - 07/01/2011
While streaming the video, I obtained a message displayed over the player window as "This content doesn't seem to be working. Try again later". I copied the internal error:
EMP v.3.0.0.r426652_426614_1 Playlist URL : <http://playlists.bbc.co.uk/news/10462520A/playlist.sxml>.
Error code : CDN Redundancy Manager Error [0]:null.
Fix CDN redundancy manager error : null
Hi Zik!
You are very clever to copy the error message so that your error could be analyzed and the solution is given. Your error is CDN and its meaning is 'Content Distribution Network or Content Delivery Network’. This error appears when different copies of data are found on several computer terminals at different nodes of the network.
The solution is to refresh the page and the slider shall not be moved because the moving might be the cause. You could find further details about CDN on Wikipedia. Â
Hope this could helps.
Hi there user:
Make sure you have all of these to get rid of the error. Adobe flash installed, can watch flash streaming videos for sites, version of Ubuntu, easy to access BBC Videos as you browse. If you have these all, then there should be a problem in the browser.
Thanks for asking here at techyv.com. Feel free to post more questions.
