Fix The Error 651 On Internet Connection.
I face error 651 on internet connection when I try to connect to my internet connection. How to fix it? How to resolve error 651 on internet connection in Windows7?
To remove error 651 on internet connection follow the instructions given below.
1. It may be possible that registry of your computer is corrupted and damaged, so clean and repair it. Install a system repair tool like Total System Care to fix your registry.
2. If still the issue is not resolved then reset TCP/IP Settings. To do so open Command Prompt and type TAKEOWN /F”C:Windowssystem32driversraspppoe.sys” ICACLS “C:Windowssystem32driversraspppoe.sys” /grant administrators:F. Press Enter.
Close the command prompt. Now traverse this folder path
C:Windowssystem32drivers. Rename the raspppoe.sys file to rasPPPoE.sys.
Right-click on ‘save the link as Vista RAS PPPoE Driver ’and then save it in the C:Windowssystem32drivers folder.
Now restart your computer.
