2. I recently downloaded a software which fixes errors on your PC. I downloaded this from a website called glarysoft.com.
This seemed to be too good to be true and it was. After downloading it I Didn't notice the errors reducing and this kept on happening.
Does anyone know which is the best software out there I could use to fix windows errors? Please help.
Fix Error Issues On PC
Hey Arnold!
There are many software in the market that can fix windows error like windows registry etc,
But many of them are not good and not user friendly,
The software i suggest you is Tune up utilities, I am personally using this software.
It's very user friendly and very easy. It will fix your entire corrupted windows registry, defrag all your hard drives,
And delete all your temporary files.
This software boosts the windows speed. My windows is working perfectly. That’s what my opinion is.
You can search and download it from the Google
Here is a link too: TuneUp Utilities 2013 – Download
Thanks
Tunacao Caaron
Errors can’t be avoided in computer even if you are using it the right way. Errors happen during program operation and when a program is interacting or communicating with hardware. Errors can affect your system in many different ways. It can cause a slow performance on your computer, make applications malfunction, consume space, cause conflict with other programs, and so on.
To fix errors on your computer that you are not aware of, download PC Tools Performance Toolkit. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. The program features a 1-click optimization button. It can fix errors on your system both file and registry and optimizes your system’s performance.
If you want to do the fixing manually, you can check the functions in every tab: Performance, Privacy, and Recovery.
