Fix The Error Message: Access Control Configuration Prevents Your Request
Hello folks,
I’ve been facing a strange problem. Whenever I try to open “www.muhammadniaz.blogspot.in”, I get an error message that says “access control configuration prevents your request.” What is the solution to this problem?
Answered By 0 points N/A #157258
This problem is maybe because the Squid Server is responsible for this message to be displayed. To solve this problem, you must check whether the Proxy Configuration in the browser that you are using, is same as the Proxy Configuration in the Internet Explorer. To check the Proxy Configuration in Internet Explorer, follow the steps.
1) Click on “Tools” option on the toolbar.
2) Select “Options” then, select “General” option.
3) Click on “Connection Settings”.
4) Ensure that the Proxy addresses and the Port are same as the other browsers.
