Fix fatal error autodesk 2012
There are times during the installation an unaware user will not suspect any incompatibility issue while doing the installation on the program. This is very common to programs and I am also one of the users who experienced successfully installing an incompatible software on my computer. In your eagerness to install that application you already forgot to check whether if it is compatible with your operating system or not and that what happens to me. I didn’t detect any problem during the installation because the whole process successfully finished in no time.
It is only when I tried starting the program when the error start showing. The program totally doesn’t want to start. I immediately suspected, since I didn’t checked its specifications, that it might be incompatible with my system. And I am right when I visited its site it doesn’t support my platform and requires a much lower version of my operating system. Since you are receiving an error, it could be a sign that your version of AutoCAD is not compatible with your platform. Since you are using Windows 7, see if your edition is Enterprise, Ultimate, or Professional because these are only the versions AutoCAD 2012 will work.
A “fatal error” on a program is like totally crashing of the entire process. If you are having this error, the application will never work even if you change settings on your computer. “Fatal errors” on a program are triggered from within the application itself with relation to the environment where it is running. To see if the problem has something to do with corrupted files, try reinstalling the program and see the result. If not, check your machine is specifications with the program is system requirements by visiting AUTODESK | Services and Support | Autodesk AutoCAD Services and Support.
