Fix For Adobe Captivate Has Stopped Working Error
I have been using Adobe Captivate 4  for quite some time. I started getting a message saying that Adobe Captivate will stop working. Earlier this message was occasional, but then it became frequent, and now Adobe Captivate has stopped working. Please help.
Answered By 0 points N/A #289483
qa-featured 5f
Solution1:- Try reinstalling the program or updating it. This would solve the issue in most cases. If the problem persists follow the solution 2.
Solution 2- There might be a problem with DLL files. Go to three link given below and follow the instructions to replace it fix the DLL files and fix the issue.
https://forums.adobe.com/thread/1064848
