Fix For Samsung Galaxy S5 Settings Has Stopped Error
I am constantly getting the Samsung Galaxy S5 settings has stopped error. I tried restarting the device but it did not fix it. Need help with this problem.
Solution-1
Try clearing the cache on your phone.
To clear cache go to settings and then storage and then clear cache. This will solve the problem for most of the people.
Solution-2
Try wiping the cache partition after going into recovery mode
To go into recovery mode swtch off your device and during time of startup press home, power and volume down button at the same time. In recovery mode using volume button go to wipe cache partition and then select it using power button and then reboot.
Notifications
