Fix For Windowsupdate_80243004
Is there a way to fix the windowsupdate_80243004 error code that had prompted when I tried to install an update for my Windows 8 computers?
Yes, there are some solutions to this issue. Check if these solutions worked for you or not:
• Temporarily switch off the anti-virus.
• Open SFC and scan your device using CMD by typing SFC/, to check whether there is any corrupt file in the system or not. Now restart your PC.
• Press Windows key and R at the same time, type %windir% and then press Enter.
• Now search for the file named WindowsUpdate.
• Press Windows key and R at the same time, type C:\Windows\Logs\CBS and press Enter to collect the log file and resolving the issue.
Notifications
